Measuring for longer Travel Shock with a hmmmm | Ford Explorer Forums
zhanx
Up state NY
2000 xls
Ok i measured the stock front shocks
5.5" almost of travel - wow even
Extened 18.75 maybe a tad more
Colased 13.5
which give a stock travel of 5.25" or so (just a tad more)
Disconnected the top and jacked up the el trucko. Got 20.6 top to bottom
the shock sits at 18.5 on the pavement level - thats only a 1/4 inch of travel i measured 4 times.
With stem to eye adapters i will lose/gain 1/2 of height
With jks bar pin eliminators i love .41 so about an 1. ( 20 tj front shocks the top matches the bottom of the explorer so i can use these to hold the bottom of the shock)
A Bilstein 8" travel shoch is 13.58 colapsed with adapter 14.58 (still room to travel up and max up my upward travel due to bump stops by 1/2 or so)
It has a Extened length of 21.54 with adapters it with be 22.54 or so which will leave 2" of travel left in the shock and bind everything up in the cv's
A 6.5 travel is only 18.5 extended and 12.00 collapsed - with adapters it only goves me an inch more travel.
Now should i go with the 8" travel shock and limit strap it after 3" since after that i start to bind or should i play it safe and go with the 6.5 and not really gain anything and continue to use the shock as a limit strap in the front. Right my front shocks are toast and i still haven't had time to start/finish my SAS planning which looks like i might start next summer now due to time and school etc.
The post is a little confusing.
Are you trying to fit the longest shock possible in the stock location?
What else do you have for suspension? Drop brackets? Extended radius arms?
<- Title says all measuring for a longer travel. i.e longer but at the same time not trying to break my junk. gave all the measurement cause i had them and i know some people would want them. thinking of just getting the 8" travel and straps.
8" travel and straps would be your best bet, you dont want your shock limiting your droop.
fyi jks bar pin eliminators are a perfect fit. Part number PN9603 for the front top of a TJ works for the from bottom shocks of the 2nd gen.
correction - you have to ream out the hole with a 3/8 drill drill seems the stock hole is metric and than its just a little tight fot it to fit and the kit is standard. easy fix and allows for more shock options.
