MyExplorer03v8Lim
- June 20, 2016
- 2003 Explorer 4.6L
My 2003 Explorer Limited 4.6 L v8 seized while on the highway. I have come to believe that the culprit was a failed oil pump, and possibly head gasket or head.
The mechanic has not gone to any great lengths to attempt to repair the vehicle because he believes it's junk. I'm starting to come around to that idea too. It has 155k miles, so even with a repaired engine it'll still have all the problems a vehicle of this age and use should expect down the line... drivetrain, transfer case, differential, suspension etc...
Furthermore my mechanic said that so long as the engine is seized, it's basically locked in place and cannot be removed. He also said there's no way to rotate something that needs to be rotated, in order to allow the engine to be separated from the transmission, there are bolts on a revolving plate, and as long as the engine cannot rotate, those bolts are hidden. He went on to add that there's no way to remove the transmission and the engine from the vehicle together, and that because of this the engine and transmission are locked in the dead vehicle for life.
I cannot wrap my mind around this. Did ford really engineer this vehicle so that if the engine is seized, there's absolutely no way to remove it from the vehicle?
