Well, in YOUR case, you will want a hub that isn't as solid as your Front Lincoln Locker.
In the front end assembly if something binds, and is going to break, don't you want it to be the EASIEST thing to get to? Lets say you went with the Warn Hubs designed for the Jeep (there are a couple write-ups on how to do it). It is a fairly strong Hub design. You will have difficulty breaking one with a stock Explorer. But once you have an indestructable hub assembly, wha' you WILL break is an Axle. Where do you want your weakest link? The AXLE, or the Hub? The axle is a PITA to remove/replace. The Hub on the other hand is nothing more than 5 bolts to remove the wheel. If you break a hub on the trail, AND you have a spare, you can be up and running again faster than if you had a flat round rollie thing. wha' is that.....10, 15 min? I'd like to see ANYONE swap an axle in a TTB D35 in less than 30 min.
I would go with the Warn Manuals (I did, actually). They have a Lifetime Warranty. I sent my hubs (w/ Receipt and Returns Authorization) to them on a Monday. And by Friday I had New Hubs back in my hands. I just used my Factory Auto's in the mean time.
But that's just my opinion. I could be wrong.
Ryan
