mengjin89
- August 14, 2010
- pa
- 1999 eddie beauer
Here is my new mods.
1st pic is high beam on, some expensive sylvania bulbs 55w h1, high beam and low beam together.
2nd is low beam with fog lights, VVME 55w and projector headlight frame for low beam, CCFL rings, driver's side fog 35w VVME, passenger 100w halogen, 100w halogen gives less output than 35w!
I did the 35w driver's side today. Very painful, Ford used a special bulb socket(with a h1 in) for stock eddie bauer fog lights, it is like a 9005/9006, but does not fit, so I use a H1 HID bulb with some round foam fills in the hole, a little shake, but OK while I drive at midight, some more pictures and videos available if you want to see. I adjust the headlights to the highest
I suggest you guys to upgrade your fogs to HID if you want to use this headlight assembly, or you will feel weird about adjusting headlight heights.
It drives like during the day after this mod in midnight. I won't try to light up high beam unless necessary as it is going to blind people.
