More grating noise 02 Eddie --Help | Ford Explorer Forums
Boxwrench
Millsboro,de
2002 explorer
2002 EddieLimited 95k mi.I recently replaced both front wheel bearings and both axles.Runs fine on the straight but at low speed turning the wheel either direction even just a little it makes a grating noise. It is lots worse when it heats up to full running temps,with the lubes thinning out.I pulled the fuses on the front drive.
OK can turning the wheel put enough resistance on the rear axles or bearings to make noise,assuming one or the other is bad.The rear has a low humming noise once warmed up.How can I check this problem.
What else cold be wrong. Thanks for any help.
Boxwrench
