motor replacement | Ford Explorer Forums
motor replacement
Fordsgalore4
La Habra California
94 EX, 86 Ranger
I got a 1999 2x4 explorer with 210,000 miles on it and its in need of a newer motor it had a blown head gasket and rod knock noise and has over heated a few times, its got a 4.0 SHOC with a auto trans what ford cars can I get the motor from that will bolt and plug right in thank you
2005 Mustang long-block is a common choice, but don't spend more than $500-$600 and do the work yourself or it's not worth it.
SOHC V6 long block
The long block from any vehicle with the Ford SOHC V6 will work: Explorer, Mountaineer, Ranger, Mustang. However, some of the accessories, engine wiring harness, fuel rails, valve covers, throttle body, EGR pipe, and sensors may have to be swapped from your current engine to the replacement to be compatible with the PCM and other wiring. For a direct swap you probably should get a 1999 or 2000 Explorer or Mountaineer engine. The engine in a 4WD has the balance shaft while the engine in a 2WD doesn't. In my opinion that doesn't matter unless you do a lot of high rev off road driving.
ya all my other stuff its good I just need the long block with heads and in tacked time chains and its a 2x4 so no off roading at all its just a city driver
and I do plan on doing the motor swap my self with a few friends I got a few quotes and they all made me gasp for air
