Motor revving when cold and bad gas mileage | Ford Explorer Forums
huntingdeer
alabama
97 ford explorer
97 ford explorer 4.0 4x4
The codes I'm getting is p1504 p1409 p0401 p1762.ive cleaned the idle control valve.no luck. What's next?
EGR? OHV? SOHC?
P1504 Intake Air Control circuit malfunction
P1409 EGR Vacuum Regulator circuit malfunction/Electronic Vacuum Regulator Control circuit fault
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P1762 Transmission system problems
http://www.explorerforum.com/forums/showthread.php?t=298880
Ok I tested the erg valve and it's good.could the idle control valve cause this?
I unplugged the iac and it does not rev up like it did.if that helps any?
What do you mean Motor Reving when cold?
A drastic drop in gas mileage is one of the symptoms of a bad TPS.
