Ski-Patroller
- January 28, 2013
- Portland Oregon
- 1997 AeroStar 2004 Miata
All the sudden I have no dash lights. That includes the clock and radio, when the headlights are on. I checked the #13 Fuse and even though it appeared good, I replaced it. No Joy.
The only other thing I noticed is that I can't turn the Dome light on by twisting the headlight/dash light switch. As far as I can see everything else is working normally.
The only other thing is that I have had a Code Scanner hooked up for a a couple of hours and I did unplug it while the engine was running. The Scanner still works fine on the van, so I don't think that had anything to do with the dash lights.
I'm thinking the headlight/dash light switch decided it was time to die, but I'm looking for other suggestions before I try to take it out.
Does anyone know if the dome light and dash lights are fed by the same circuit? The dome light still works ok when I open a door, just not from the dash switch.
