My Advice on Check Engine Light | Ford Explorer Forums
Ira
Northeast Tennessee
91 XLT 4x4
This information is primarily for the earlier models since that is what I am becoming familiar with. I just wanted to share this info so that you may not have the headaches like I have.
I have been plagued with the famous Check Engine Light off and on for about 3 months now. The fuel economy also seemed to suffer intermittently. I have just replaced 3 oxygen sensors in the last 2 months on mine. I know you are wondering why. The first one I replaced was bad. I know this because as soon as I put it in and drove it, 10 minutes later, the light came on again. I made a test harness and plugged it into the O2 harness and found I was not getting a changing signal like I should. I took it back and replaced it. The light came on once with the second new one and that was the first day. I later checked it and it was giving the voltages that it should. About 2 weeks ago, the light started coming on again but not everyday. I got mad because I figured I had another defective sensor so I took it back to AutoZone and they refunded my money. I told them I had better things to do than keep climbing under there and changing sensors out. I went to Ford and bought one from them. About 2 days later, the light came on again. Did I mention that I had checked the codes before and had one for a bad O2 sensor at first? After I changed it, I never got that code again. It was just saying the mixture was too rich or too lean.
A couple of weeks ago, while sitting at the drive-up at my bank, I noticed the engine would surge at idle. It would go up 200-300 RPM and then back down. It did this continuously until today. I got my fuel pressure gauge out and checked my pressure again, like I have a couple of times since the O2 deal was going on. It is supposed to read around 30-45 at idle. It was reading 38 just like it has been before. Suddenly, it jumped up to 70 and fluctuated and never dropped back down. When this happened, the idle speed surged up and down. Before doing this, I disconnected the vacuum line from the fuel pressure regulator and had NO fuel coming out of it since I suspected it was letting fuel dump back into the engine thru this line. I thought it was OK because it was dry. When I saw the pressure jump, I replaced it. Now I have more power and engine is idleing smoothly, even at 170K miles. When I restarted it after replacing the FPR, I floored it once and covered the ground with carbon that blew out of the tailpipe.
Moral of the story...just because it may test to be good, it may not be. I was just lucky to get it to finally surge while I had the meter on it. Since the early models, like mine, do not have an engine code specifically for the FPR, the O2 sensor is many times the code you will get or you will get the ones that say rich mixture or lean mixture.
Another thing to consider is that when the FPR does go bad and stick like mine did, over a short period of time, the O2 sensor can in a sense be "fouled out" by the carbon from the excess fuel being burned and cause it to read as being bad. That is what I think happened. If you pull your O2 sensor out and the end is very black, do yourself a favor and replace the FPR first before replacing the O2 sensor. If the FPR was at fault, after replacing it, the exhaust may possibly get hot enough to burn the carbon off the O2 sensor and it will start working.
Been there...done that.
BTW, my check engine light would not come on until after driving for 10-15 minutes at least. I think what happened at AutoZone was that I did in fact have a defective O2 sensor at first and the second one went out because of the FPR.
From what I understand about the way the FPR works, fuel is supplied to one fitting, vacuum is supplied to another fitting, and it has a third fitting that goes into the fuel rail (fuel at regulated pressure). As fuel is supplied from the fuel pump to the inlet fuel fitting, it is under high pressure. The purpose of the regulator is to keep a constant lower pressure (30-45 PSI) supplied to the engine, or fuel rail. As the engine RPM increases, the vacuum will compensate for the extra fuel needed or used by the engine and keep it regulated.
From what I have heard and have figured out on my own, either of 2 things can happen causing it to fail. The first is that the FPR will leak fuel internally from the high pressure side thru the vacuum and this fuel will cause the engine to run RICH. The second thing is that the regulator will stick (which is what happened to mine) and dump high pressure fuel into the fuel rail. It is possible that when it sticks like mine did, it can be intermittent. It can stick for a few seconds, minutes, or even days and then decide to loosen up and work correctly again. This is why my fuel economy seemed to be up on one tank and down on another tank when the same conditions were present on each tank (highway/city combined mileages were similar on each trip/tank).
I just wanted to post this to try and help out other people with the same problem. I know there are plenty of other posts on the subject, but none of them seemed to directly describe what was happening with mine.
Good luck and hopefully this will prevent you from getting the headaches like I had.
Ira
91 XLT 4x4
Once I thought I was wrong, but I was mistaken.
[This message has been edited by Ira (edited 03-23-2000).]
Ira,
I have been having the exact problem you had (except the surging). I replaced the FPR but now have found (read EEC need info fast thread) that I need a new O2 sensor. Is it safe to get a Bosch or should I buy one from Ford? I know they're the same but from your post it sounds as though something is different with the Ford sensor.
I have two part numbers for the Bosch sensor 13187 and 13225 (for 4X4). I have a 1991 4X4 two door, which one is the one I should buy? Also, how hard are these to replace? It seems like I only need to unplug and use a wrench to take it off. Could you post a play by play on the procedure, there is no posting on this on the board. Thanks!
I also got a third part number from a tech at carparts.com 13128...there all Bosch, but which one is for me? He says its definately 13128 and not the others.
[Edited by Triton46 on 09-05-2000 at 07:22 PM]
Ira, thanks for posting that. A very good explanation of things that I wasn't aware of. Triton, I'm glad you caught this, as it relates to your problem.
After replacing the FPR, it would not be a bad idea to replace the O2 sensor. When the FPR goes out, it will cause the engine to run so rich that it can cause the O2 sensor to malfunction.
I am not sure exactly what the part # is because that has been a while. When I asked for one from the $tealership, he said there was either 2 or 3 that it could be and wanted the old one and used it to match it up. From what I remember, the sensor was the same, only the connectors are different. I would not really condemn the Bosch brand even though I did have a couple that were defective. The first was probably just bad from the start, and the second probably went bad because of running with the excess amount of fuel from a defective FPR.
As for play-by-play, it is simple. The hardest part of it that I found was trying to disconnect/reconnect the electrical harness. It is difficult to reach and you do not have room to use both hands, or at least I didn't.
Here are the steps...First, disconnect the harness so it will not get twisted up. Second, climb under and remove the O2 sensor that is located in the exhaust where it first comes down from the engine. You do not have to have a special O2 wrench to do it...you can use a standard wrench but you can only get it to turn so far with each turn...just be patient. Next, install the new sensor, but wait until you get the sensor tightened before you plug the harness in because it will get twisted and possibly damage the harness.
Good luck!!!
Mission Complete!!!!
OK, the O2 sensor is out. I was scared about this job at first. The old sensor is almost rusted to the exhaust and the harness it plugs into was very hard to reach. I managed to unplug the harness and had to get a grip on the old O2 sensor with the pliers. I wound up bending it to get a grip but it came out pretty easily. The sensor end was covered in carbon, its no wonder the computer didn't think there was even a sensor there. Note: the harness was not attached to anything even though it had one pressure screw attached and was flopping around.
I then put the new sensor in and hand tightened. Then took a small turn with vice grips to tighten. I hooked up the harness then pushed the pressure screw into a hole on the back of the engine. Im not sure what I attached it too, but it has to be better than flopping around. Im about to go test drive.
Part number is Bosch 13128.
Success! I went for a drive down the highway and through some small towns for about 40 miles round trip, no Check Engine. We'll see if this holds up.
While I was out, I filled up with gas. MPG before the FPR on a 600 mile trip was 15 to 17. MPG from the Pa trip after the FPR is 19.22. Thanks to all for their help.
Cheers!
Thanks for the information. I had just purchased my 91 Exp and I am experiencing the same problems with it. The check engine light is coming on around 15 minutes or so of driving, when I am sitting at a red light the vehicle is surging, every once in a while it will stall while sitting at a stop. I will watch the tach shoot up a couple hundred of RPM's then take a second to drop back down. I just replaced the O2 sensor, since the codes I received were that it's running too rich and the O2 was bad. Once I replaced the O2 the engine ran fine for about 15 minutes and went back to the same thing it was doing prior to the replacement of the O2. Also, the old O2 was covered in carbon.
I will replace the FPR and see what happens.
thank you, thank you, thank you
I've been chasing down what I thought was an endless parade of bad O2 sensors. I'm gonna give this a go because I'm having EXACTLY the same symptoms. I'll let you know, but thanks again. It would've taken forever for me to consider the FPR.
I replaced my Fuel Pressure Regulator yesterday the explorer is running like a champ. The check engine light isn't coming on anymore either. I just have one other thing, I am now idleing at about 1300 while sitting in park, then when I drop it into drive the tach drops to about 900 to a 1000. Also while I am driving when I take my foot off the accelarator the RPM's don't drop for a few seconds its like I have the cruise control set when I don't. Any ideas out there? The tempature gauge is reading normal also.
Did you hook up the vacuum line and does it fit snug? check all other areas for vac leak as well.
