My van runs rough after a warm start. | Ford Explorer Forums
Icuff4cash
Las vegas
1994 aerostar awd
for a year,I've had a problem with the monster aka pug shuttle shaking when starting after being warmed up. I was told and I did the following. Clean map,replace map,replace oxy sen,used a can of sea foam green every month at fillup to clean injectors, now my buddy josh said maybe the temp sender. Well here's an old write up explaining my proble. What do you think. Van starts great cold. Once warm it fluids out and shakes for 10 seconds then fine until I shut it off again. Only in the summer is it bad.
#4
aerocolorado
Postmaster
Both the Engine Coolant Temperature sensor (ECT) and the Engine Temperature Gauge Sensor are thermistors - temperature sensitive devices that change resistance with changes in temperature. The ECT is especially important as it sends temperature information to the computer "brain" (powertrain control module) which in turn uses that information to regulate how rich or lean the engine runs. Obviously, if the ECT is not functioning, the "brain" thinks the engine is always cold and thus keeps things in a rich state, wasting fuel. These sensors do slowly go bad over the years. There are charts whereby you can test their functionality based on ambient temperature and resulting resistance readouts, but I find greater ease of mind just to change it out if in doubt.
Those of you with low reading dashboard temperature gauges, suffer from essential the same problem, a poorly functioning sensor. These sensors have a single wire rather than the two wire, larger ECT sensor - and best of all they are dirt cheap, often going for around $5-6 at most parts stores. I drove around for several years thinking I had a really efficient cooling system as it never registered above "N". I had lots of heat but always a low reading. One day, it dawned on me the sensor might be the problem - it was. Now it reads dead mid range where its supposed to be.
I say a lot of things, but I'm not always correct. From personal experience I would have changed all the parts you did to troubleshoot this. Evap canister would be next on the list.
You have never been wrong yet. Last year I started the van and by the time I got to the light at the end of the street it swing over to hot. I drove 100 feet down to cold. But it made sense even this guy said the temp unit will make it run rich,acts why it must load up when warm and if I hit the gas. It farts and shakes for 10 seconds. Ecu tem is $27.00 gauge unit is $7.00 I'll replace both. It's going to be starting in the 70 by wed. If it is I'll play dentis and give the monster new choppers to eat those baby crv's opps I mean seals.
The 4.0L engines tend to have intake gasket issues with high mileage. Spray intake cleaner around the intake manifold with the engine running to see if the idle changes. Do you have a check engine light?
No light, my problem started last summer when I mention the hard start. When warmed up if I taped the gas it would shake for 10 seconds and smell like it flooded you mention the above to try and I replaced everything. I never dealt with duke njection I'm a Holley person old school. So the other day I found an article about the water temp tells the ecu how much fuel to give it.someone mention it also. Today the van ran great on it first 50 mile trip since I swapped the big tires no lift no hit. But the tem gauge kept bouncing then stop them bounce again. I have 155,000 and I don't know how much the original owner replaced exsepct for the receipts that they gave me.
