name that part | Ford Explorer Forums
name that part
trackerjoe
origin-Manchester,TN current-Parris Island,SC
2001 Volvo s80 i6
what part does the upper radiator hose connect to? i have a slow coolant leak and the joints(maybe a seal/gasket there?) of said part were wet. is there a seal sandwiched there thats gone bad? solution/fix?
**no overheating, overflow tank never stays full, when i do have fill the radiator i only have to top it off.
thanks in advance
Do you mean the thermostat housing?
getimage.php
YES! lol, i just found that from about an hr of searching the forum. i feel silly now for not knowing. it looks like a pita to replace!
im still unsure on what i actually need to replace. its leaking slowly from the seems... just o-rings?
Yep. Its like a buck 25 at the parts store. I just changed mine out too. Actually turns out whoever did it before didn't even put a ring in! Just siliconed the mess out of it and somehow it held together for almost two years.
can you confirm p/n? found these off the how-to. also what would merit replacing the whole assembly? do i fix it if it isnt broken?
1L2Z-8255-AA RG614 -lower thermostat housing seal
W702837-S300 -thermostat seal (aka large o-ring)
http://www.explorerforum.com/forums/showthread.php?t=306984&highlight=thermostat
If you are pulling it apart you may as well throw in a new thermostat. They are only good for so long, and you are going to be right there. They are pretty cheap.
