Need Advice.... | Ford Explorer Forums
Need Advice....
nyc_medic
Long Isalnd, New York
1999 Mountaineer
Hello All,
I'm in need of some advice about what kind of motor mounts and transmission mounts I should use. Are the factory replacements good or should i try something else. Does energy suspension make mounts for the explorers and mountaineers? Are they any good. Thanks for your input.
I would go with the factory OEM stuff.
Yes, Factory are Just Fine!!
The poly bushings might hold up longer -- but I dunno if anyone makes some for the Explorer. But the OEM factory stuff is just fine - if not better. Usually can't go wrong with origional equipment.
-Drew
