rww
- June 8, 2006
- Alaska
- 94 XL - Modified
This engine has a CID / Cam position sensor. It is chirping which means the entire assembly needs replaced. . . . .the small sensor part on top that normally fails is in good shape . . oh the irony of it all. . . .
Since this 94 engine has a CID on it, it means that the enigine is either a CA Emissions engine (vehicle was bought brand new in Washington State - we are the original owners) or Ford stuffed an early 95 engine into the 94 model (Ford used to be notorious for that trick). . . be what it may does anyone know if the 95 CID / Cam Position Sensor will work in the 94? This part is not available anywhere. . . . . Part number is 92TF-12k073-AA
