Need help getting rid of a noise, a clunk. | Ford Explorer Forums
Status
Not open for further replies.
wmorrisw
SCHAUMBURG, IL
1998 EXPLORER SPORT
I just got a 1998 Explorer Sport 4.0 sohc, 120,000 miles. The clunk seams to be coming from the rear suspension. You can only hear it when coming to a complete stop. It sounds like a set of golf club moving around in a trunk. If you come to a very easy pampered stop it will Not make the clunk.
I removed the spare tire. Not it.
Took it to local shop. Put up in the air, Test drove. No help.
Took to Firestone. Put up in the air, Test drove. No help.
Both could hear the noise, but couldn’t pin point it.
This is the last thing I need to do to get it in near mint mechanical shape. Got rid of two engine codes ( 02 sensors), door ajar light, rear wiper now work, rear hatch button is replaced so it can be locked and alarm works, got lumbar working in passenger seat, wired in new bulb to driving light, dash light, and found the code for the keyless entry. Found out nothing is wrong with the 4 wheel low (Just can’t use it unless the tires can slip)
But I need help more on this!
Status
