- August 1, 2008
- MO MO
- 94 & 95 XLT's
Having trouble finding a 12mm x 1.0 bubble flare Tee fitting. (3 hole block works as well)
The thread is 12mm x 1.0 on the front brake lines going into the HCU (abs pump) and to the front line on the master cylinder.
I need to connect all three together using the Tee fitting. Problem is I can't find one anywhere.
If somebody knows where to find adapter fittings that change the 12mm x 1.0 to an American 3/16 thread, that would work as well. I can find 3/16 Tee fittings everywhere.
If I could get any help here in this, I would appreciate it a bunch.
Web Links, Company names, supply stores, etc...
Thanks!
Thanks!
