thezet
- April 22, 2009
- 2003 merc mountaineer 4.6
Hey guys,
I've done a lot of reading in this forum and must admit that this is the best forum ever
I have a problem that has been discussed in a couple threads here; unfortunately none of the proposed solutions work for me.
Quick description:
Engine stalls at low rpm when warmed up. When I start it up in the cold, everything is fine. Once the engine reaches temperature, when in idle, the rpm keeps dropping to 500 and then back to 1000, back and forth. After a while, the rpms drop to below 500 and the engine stalls. This happens in idle or when driving and coming to a stop. I checked the TPS and it is okay. No error codes popped up so far and the problem began slowly and got increasingly worse in the span of two days. Above rpm car sounds and drives just fine, as if there was no issue at all. Checked for vacuum leaks and found none.
I cleaned the MAF and it looks like new, however I don't know if I get the appropriate reading on the terminals of the MAF/IAT.
I finally got codes P0113 and P0122 today, but I think the P0122 is from unplugging the TPS with the engine running.
I've done some resistance measurements on the TPS and the MAF/IAT. the TPS turned out ok, which was a consistent resistance increase/decrease while working the throttle.
According to my docs from autozone members area, the wiring to the MAF/IAT should be as follows
and in the test instructions for the IAF, it says to check the resistance between IAT and the SIGRTN, which are according to the diagram pin 1&2.
Am I correct about this? I've read the table and know I should be at room temperature at 3-4 KOhms.
Here is the plug from my MAF/IAT
And here are the readings I've got on those pins.
As I understand
1 - IAT
2 - SIG RTN
3 - MAF
4 - MAF RTN
5 - PWRGRND
6 - VPWR
My reading in resistance are;
1 - 2 UNLIM OHMS (OL)
1 - 6 78.2 kOHM
3 - 4 0OHM
2 - 5, 3 - 5, 4 - 5, 22.7 kOHM (I guess thats to ground)
Could someone confirm these readings, or does my open/unlimited OHM between 1 - 2 indicate a faulty IAT? or a faulty connection?
I took the MAF out and measured directly on the IAT metal pins right below the thermic resistor and got a 33 kOhm reading that reduced while i blew hot air on it. So I am confused whether I am trying to measure the wrong pins on the connector or whether the wires inside the MAF are messed up, or maybe if I am going crazy...
I would appreciate any help
Alexander Gwosdz
P.S.: It's a 2003 Mountaineer V8 4.6L with 120k and might need a new fuel filter
Quick description:
As I understand
1 - IAT
2 - SIG RTN
3 - MAF
4 - MAF RTN
5 - PWRGRND
6 - VPWR
1 - 6 78.2 kOHM
3 - 4 0OHM
Alexander Gwosdz
