glfredrick
- January 25, 2003
- Sheboygan, WI
- 2014 Explorer Limited
I recently had opportunity to use a Snap On Color Graphing Scanner for the weekend and tried to run the codes on my 97 4.0 SOHC/auto/4x4.
The scanner came up with this code when I did a KOEO test.
"P1000 OBDII System Checks Incomplete"
It refused to check the computer - even after I cleared the codes and tried again.
When I tried the KOEO test, the scanner just went crazy and didn't read anything.
I recorded a few drivability parameters if they mean anything that helps...
TA (v) 1.04
Load % 28
ECT (v) 8.6
Bard (K/v) 101
Bard (Hz) 158
ECT (*c) 79
IAC 0
IAT (v) 2.68
IAT (*c) 27
02511 (Mv) 1
o252 (Mv) 27
Open
We are having drivability issues that involve the GEM module (t-case acts weird and "locks up" at times) - dash lights don't work when the headlights are on (the warning lights like the "blinking" OD light - 4x4 light, etc. - not the illumination lights) - poor fuel milage - check engine light often comes on - and stays on, etc.
Any ideas are appreciated.
TA (v) 1.04
Load % 28
ECT (v) 8.6
Bard (K/v) 101
Bard (Hz) 158
ECT (*c) 79
IAC 0
IAT (v) 2.68
IAT (*c) 27
02511 (Mv) 1
o252 (Mv) 27
Open
