need some lift advise | Ford Explorer Forums
jlove21
westland,michigan
'93 xlt
im going to put a sas 44 into my truck and a 9" in the rear with leaf springs over the axle. i want to put 6 inches of lift on but don't know how big of radius arm drop brackets to use or what degree bushing to use for the 44. i was also wondering how big of tire i could fit.
i dont think you need a drop bracket for the radius arms; can just extend the stock ra's, buy aftermarket ones, or use bronco ra's. not 100% sure about the bronco ones though, double check that. i'm not sure about tire size, from what ive seen on the forums that axle/lift combo can fit 35s at the very least.
Your best bet is to read through a bunch of the rigs in the SAS registry and find out what has worked for guys... do some research...
