Need To Adjust Camber, What Size Socket Do I Need? | Ford Explorer Forums
njones1220
Virginia Beach, VA
1998 Explorer
I need to adjust the camber on my stock 1998 Explorer XLT. I do not have a socket that will fit it, and can't find info on the size. I'm thinking it's a 21 mm, but I would like confirmation first so I only have to make one trip to the store. Thanks in advance.
And do I need a special tool, or will a deep socket do the trick?
Do you know for sure that you have the camber cams installed? From the factory they come with spacers that have zero adjustment.
if you still have the stock OE bolts, there's no adjustment possible without getting some camber adjustment kits. Moog @ RockAuto around $18 each if I recall correctly.
