Need wiring diagram for 1998 Ranger 4x4 3.0 fuel tank pressure sensor circuit. | Ford Explorer Forums
freak
Location
Northwest Ohio
Pemberville
2000, Explorer XLS
We're getting a code for the fuel tank pressure sensor and I've like to check the circuit before replacing the sensor. Do any of you know where to get a circuit diagram for this truck's evap system?
<edited to evap>
Sorry no but it would be part of the evap system or engine controls diagrams rather than fuel system (most likely).
You could look through the 2nd gen explorer wiring diagrams linked in my sig to get a general idea of how it's probably set up.
I assume you're aware that at least one pressure sensor related fault code, could be due to a vac leak rather than the electrical sensor or wiring itself... even a gas cap with a bad seal or not screwed down all the way.
Yeah you're right evap. Yep going to check all those things. I like to check the wiring from the sensor to the computer though.
