Mussin
- February 24, 2008
- Lima,Ohio
- '02 Mountaineer
I have been battling this problem since summer. I replaced the 5R55W this summer and this problem has been here ever since. The car idles extremely rough for 2-3 minutes then smooths out and everything's fine, it chugs. If at any time you try to drive it when it is doing this it pops through the intake (extreme lean condition) and is dead in the water, no power at all, Unless you floor it, then it comes to life! At first it was just a slight hesitation but as it got colder out its alot more pronounced. I had a friend of mine who worked at a local Goodyear bring home their scanner from work so we could do some trouble shooting. Well the front oxygen sensors are showing NO voltage, the heater circuits are working properly but they are dead. The back 2 are fine. I thought what are the odds of both sensors going out at the same time?? So I bought 1 replaced it and still showed zero voltage?!?!?!?!? Well like I said at first it wasn't a big deal but now its a real PITA! I dropped it off at Local lincoln/merc dealership this morning and they call me back saying they found my problem.... "Your front O2's are not working, they are showing no voltage".... He said they can replace with Ford O2's parts and labor $414 for two o2's!!! I told him don't worry about it. He also said all the circuitry looks fine going to the sensor just nothing at the actual sensor.
My question is What the hell is going on here? I laid under the car for hours looking for a pinched wire, cut wire, I found nothing, everything looks like it did before we swapped the tranny?
Anyone have a clue?
(2002 merc mounty 4.6l V8)
THANKS
Jeremy
Anyone have a clue?
THANKS
Jeremy
