New B here, and need to know some stuff... | Ford Explorer Forums
Nine-90
CT
94 Eddie Bauer
ok, so tomrrow morning i go pick up my 94 Eddie Bauer...
what i need to know is the possibilities of swapping a 302 into it(w/ single turbo set-up) or quite possible a GM *thyphoon/cyclone setup*... now very unfamiliar with this truck, but need a decent delivery truck for the signshop and vehicle performance engineering company i own... something snazzy other than my company track car...
please no flamming i am asking serious questions w/ the outcome of hopefully some serious answers...
-Dan
Nine-90 Performance Engineering
a turbo is going to be a pain in the butt, and im not trying t obe a jerk... i hope your knowledge of engine swaps is extensive, there is a lot of stuff. the 302 has been doen by some mebers, its not an easy bolt in swap however. i dont necessarily dislike the gm typhoon platform, however to put it into an explroer seems liek a waste, just leave the typhoon drivetrain in the typhoon.... welcome to the site, and do a search for something along the lines of engine swap
Hi Dan:
If you want to put a V8 in it, and go to AWD (like the Typhoon/Syclone), you might want to consider just buying a 2nd generation Explorer with a V8 and AWD already installed from the factory. The 1st generation Explorers can have a V8 swapped in, but they weren't designed for it, so a lot of custom stuff has to be done. The early 2nd gens don't cost much more than a '94, and the elimination of all that fabrication work will probably more than offset the cost difference anyway. Once you have one with the 302, you could always build up the engine with heads, cam, stroker kit, etc. You could even put on a supercharger as long as you're willing to beef up the transmission and transfer case a bit. Turbos would be considerably more difficult.
Let us know what you decide.
P.S. - the GMC Typhoon/Syclone used a turbocharged V6, not a V8.
Regards,
John.
Toolman i know the thyphoon is a six, which is what my explorer is... im assuming space wouldnt be an issue, its just getting the drivetrain along...this is my major concern, although it would also be a concern with a 302... swapping motors is no issue, you know people say that the sr20det motor is a direct swap-in for the years of the chassis, but let me tell you, going from automatic KA to manual SR is no laughing matter, alot of drivetrain issues had to be addressed... so when it comes down to modifying and fabricating, well its what i do for a living... but regardless... still bating on the 8 or the six... anyone want to give me a heads up ?
Hi Dan:
Well, if it were a matter of picking the best drivetrain for your use (decent delivery truck), I would think torque and overall drivability are more important than maximum peak HP. That being the case, a mildly-built V8 seems a more logical choice than a turbocharged V6. I'll let others with more experience with the V8 AWD drivetrain speak to its durability, but I would think it would hold up without much modification as long as you don't go too wild. Either way, it sounds like an interesting project. Good luck.
Regards,
John.
just a small question here... for a delivery vehicle.... whats wrong with it stock... i mean its gonna see alot of hard use. If you want v8 power... then buy a 96-99 with the V8 in it and All wheel drive... they hold up really well and there are tons of small mods for it as im sure you know... other than that for a work delivery vehicle why would you need a turbo... i mean unless your need to go mach1 down the highway to get something delivered in a hurry the stock drivetrain with the v6 would even be sufficient... not trying to flame but confused as to why someone would want to make a delivery vehicle have more power than it needs to get the job done...
Not many people have undertaken the task of swapping in a motor from a manufacturer other than ford. To drop in a turbo charged v6 or a turbocharged v8 will be a large undertaking and will require a lot of researching on your part. search on yahoo for motor swap or v8 swap and you'll find out alot.
Be prepared to lose/move the A/C , and move the Radiator.....
