Red92XLT4x4
- April 7, 2005
- Temple, Tx
Hey everyone, new guy here. I just went and bought a 92 Explorer XLT 4x4 today and am looking around trying to repair some things. I've searched posts all afternoon, and I'm starting to finalize a concensus on how to fix the problems. So far, I need to address the following issues;
- Power door locks do not work, none of them from either switch. Loose connection? Solenoid bad?
- Three windows go down intermitently. From my prev. experiences with elec. motors, it looks like the motors are going out.
- Cruise Control does not engage at all, but I haven't checked the vacuum lines or the fuse yet (dark outside)
- Power Mirrors only go to the left and up on the drivers side and the right and up on the passenger side. Possible gunk buildup in the switch?
- The fuel guage is INOP, how can I fix this? new guage? or new cluster?
- There is a howl in the front axle when you engage the 4 wheel drive. A friend who works at a shop suggested an additive and fluid top off because a lot of 4x4s howl when they are not used much. Something about fluid not being distributed and taking a while to lube....
- There is something making "OD" not engage. The prev. owner said to get it into OD, he had to sweet spot it between the "OD" and the "D" so he had the shifter looked at. They "Fixed" it, but now "OD" on the column is D and so on. But Park, Reverse, and Neutral are all normal. Could it be the shifter linkage?
Sorry for posting so many questions, but I'm tired after spending 5+ hours searching through pages and pages of topics. Many helpful suggestions found, I just want to make sure the methods discussed in past threads are currently accepted means of fixing the problems mentioned above. Any suggestions would be appreciated!
