Jim Jermain
- February 20, 2006
- Madison, WI
- 00 XLS
I have a '00 Explorer with the 4.0 OHV. I replaced the cylinder heads due to a rough idle problem at cold start. Before I replaced the heads I tried just about everything else to fix my rough idle problem, (upper / lower intake gaskets, plug wires, plugs, IAC, TPS, EGR Pressure Control, cleaned MAP, fuel filter, one fuel injector - due to misfire code on cylinder 3). After replacing the heads my rough idle problem appears solved. However I am now getting a minor hesitation -stumble on acceleration around 40 MPH.
I can really use some advice. After spending several days replacing the heads, I'm really tired of trying to troubleshoot the Explorer.
Please, please share any tips you may have. The only three things I can think of are the ERG pressure differential hoses (one looked a little worn), the EGR tube o-ring, (the gasket kit that came with the heads did not include this o-ring and my old one was in rough shape. I replaced it with the closest o-ring I could find at my local hardware store) or possibly is the computer re-learning the correct fuel mixture due to the new head. I'm not sure if any of these could cause my problem.
Thanks,
Jim
Thanks,
Jim
