whtexploder
- November 21, 2009
- bellingham,wa
- 91 eb edittion
hey eveyone, got a 1991 ford explorer recently it has a 4.0L with a auto trans. the cel light came on and it was running really crappy bucking like its misfireing, and running super rich, i can see the smoke, geting like 6mpg or so.
i did a code check and it came up with 41 and 12 codes koer
i have changed the coolant temp sencor, and the t stat, after i changed the t stat the temp started reading, it wouldnt before.
also just had a new pump and fuel relay put in.
i was thinking possably the cat was cloged because the exhaust started leaking in spots really bad and it runs super rich... also the idle fluctuates but that could be from the code 12 iacv. 41 is running lean for more than 15 seconds, and idk how its running lean... another reason for thinking its the cats is the guy that had it before said its been geting at best 9mpg for a while, so i was thinking the fuel cloged the cats up... the vehicle had a full tune up in march...
any help would be much apriciated. thanks -blake
