New Option 54E 12.1" touchscreen in PIU Order Guide | Page 2 | Ford Explorer Forums
Kind of. The display is super small and the hdmi interface is a little sloppy. I found a great use for it in my demo as I have a low light forward camera for demonstration purposes. It certainly could not be used in place of an MDT system - it’s too tiny and the interface is very clumsy for a PC
It’s a 12.1 inch screen, not small at all lol 😆.
Do you have any pictures ?
Did you do the sync 3 upgrade, which allows you to use an 8” or 10” display on that screen if programmed properly?
The Sync system is irrelevant to the ICS driver running the peripheral HDMI input. The the visible resolution of say a windows based or Linux based machine is basically limited to 1/2 of the screen. Even at the full 12” because it cannot articulate- again it would be ridiculous to use as an MDT in an operational environment.
Here’s the document on the ICS to help you try to understand: https://www.lectronixinc.com/wp-content/uploads/2023/07/ICS-Owners-Manual-V1.3.pdf
