Sallad420
- March 19, 2003
- Kelowna, BC Canada
- '96 XL 4WD
Hi all, I just got a 96 Explorer XL 4WD. I love it! I used to own a Chev Cavalier
Anyways, I've noticed a few things, front end makes a slight "clunk" noise and a sweeking sound whenever I go over a small bump.
Wipers will work fine, then stop halfway up the window, then continue working after a few secs. This repeats every 5 mins or so. (is it just the switch??)
I'm having problems with the 4WD LOW. I switch it into 4low, then after a few secs the 4 low light will come on. But it doesn't like to be turned off. I put it into N the switch back to 2WD, but the light will not go out right away. only after I turn the truck off or drive around for a bit. An I doing something wrong?
Last thing... Pass side window switch doesn't work. It did, but a day ago it stopped working. The light still lights up and I can control the window from the drivers side switch, just not by using the Pass switch. The light lights up, so I'm assuming the switch is still hooked up, maybe just a cleaning of the switch or faulty switch??
Sorry for the long post, this is my fist Explorer and first 4WD, I've always had sporty little 2 dr. cars. so this is all new to me.
Thanks guys! (from a converted Chev man)
