New transfer case blowing #23 fuse | Ford Explorer Forums
covert4545
Western New York
2002 Ford Explorer XLT
Hi guys, New to the forum but have been getting great info off of here for the last years.
The issue I am having is with the 4wd, and the #23 brake light fuse blowing. The problem started when my 4wd stopped working and was only using 2wd for awhile. I read that a common issue is the Transfer case control module, so I bought a used one off Ebay for $60, I removed the old one and put in the new one, and the 4x4 low light came on but it also blew the #23 fuse and wouldnt let me get the vehicle out of park until I had working tail lights. (unless i used the override) I proceeded to hook up the old Transfer case put a new fuse in and everthing worked fine, except i could only use 2wd. So my question is did i just get a bad transfer case off of ebay? or does this have some completely separate issue with electrical shortages? or is there another diagnosis i should be looking at?
As I understand it, there are multiple units out there but they aren't compatible. Sounds crazy. Perhaps you didn't get an exact match.
Fuses usually pop when there is a short in the system. Busted or grounded wire.
In 2005 Borg Warner eliminated the speed sensors on the T-case. If you got a later T-case without speed sensors, it won't work.
