TNHellion
- July 4, 2014
- 2000 explorer
I just picked up a 2000 explorer and all was good until the A/C cut out and check engine light came on. I'm not much of a mechanic, so please dumb it down for me. I had the auto place check codes and it came back with
P0118 engine coolant temperature sensor circuit high input
1 open of sort circuit
2 electrical connection
3 faulty ect sensor
P1117engine coolant temperature sensor circuit intermittent condition
1 poor electrical connection
2 failed ect sensor
(They couldn't find a Ford code for the last one, so the printout is for a volkswagon
p1118 sensor heat circuit open bank 1 sensor 2
1 failed heated oxygen sensor bank 1 sensor 2
*edit
Found the ford p1118 code on the forum
P1118 Manifold Absolute Temperature Circuit Low Input
Like I said, I'm new to fixing my vehicles and can replace anything that I know needs to be replaced, its getting to that point that I'm usually stuck on. Should I just replace the ect sensor? The truck seems to be running fine aside from not having any A/C
3 faulty ect sensor
2 failed ect sensor
*edit
