no air coming through front vents | Ford Explorer Forums
armysoldier30263
Shaw AFB, SC
05 BLACK 4.0 XLT
Alright Gang. I need yall's help again. The air is coming through the floor vents, center console for the back seat, and defroster like normal but there is no air coming out of the vents on the dash. When you adjust the knob on the dash my wife says everything works as it should except for the dash vents. Anyone had this issue before?
Auto air or manual??? (the ac not the trans...)
If it's auto it could be the dreaded blend door motor problem... Do a search on here...
I have manual air. From what I read the blend door changes the temperature of the incoming air. My problem seems to be is the knob that changes from the floor to dash to defrost etc.
I have that same issue. My problem is I could put the knob on vent/floor and the air will come out the defrost vents. Or I could put it on defrost and it comes out the floor or the vents. It's frustrating.
I have no air coming out of my dash vents either, regardless of the setting it's on.
