Originally posted by Road Turtle
Anyone have any ideas on a ready made kit to turbo the 4.0 OHV? Im not against superchargers, I just know tubbochargers deliver more power more efficiently, and turbo lag is a thing of the past. So howbout it anyone know anything? Maybe somone working on a future project, don't be stingy share your info.
First: There are no off the shelf turbo kits for the 4.0
Second: When you send Troll your check, leave room for lots of 0s
Third: Turbo lag is alive and well.
Lag is simply the time it takes for a turbo to spool up. Smaller turbos spool fast but don’t offer high-end power. Large turbos have longer lag times but produce big HP. Superchargers are perfect for someone who wants added torque across a grater RPM range. Turbos have the advantage of being more durable then a supercharger. If you want power across the board, get a supercharger.
I have been working on a turbocharged 4.0 for over a year (thanks to my brother in law’s procrastination) and I’ll tell you what I have learned so far:
1) It is always much more expensive then you think
2) It is always much more complicated then you think
3) It will always take longer then you think
4) The first three rules are gross understatements.
A complete supercharger system for the 4.0 is about $3,000.
Turbo - $1,700 to $4,000 each
Custom exhaust manifold - $500 - $1,000
Intercooler - $1,000 to $2,000
Electronics - $600 to $1,200
Misc. - $1000 – up
Unless you have access to a pro shop, have huge bucks or are otherwise a mechanical god, you’re asking for a boatload of headaches.
Contrary to how this sounds, I’m not trying to detour you. I’m only trying to press upon you the complexity of this project your contemplating. One year ago I didn’t know jack about turbochargers. Today, after reading over a dozen books and talking to more pros then I can remember, I consider myself a well-educated amateur.
I recommend, if your serious about wanting to build a turbocharger system for your 4.0, read “Maximum Boost” by Corky Bell. This is a good start.
Just my 2 cents
