Not the alternator ! | Ford Explorer Forums
JEK
WISCONSIN
1997 XLT V8 AWD
Hi All, I have a 1997 Explorer
When it is very cold -degrees my headlights and fan dim and my voltage gauge goes low, only when I come to a stop, as soon as I give it a little gas or put in neutral the gauge goes back up. Put a new alternator in , but still does it only when very cold ??
Any help would be great :)
Thanks, John
I donno much about electrical stuff but maybe it's the battery? Sounds like you got more of a load than the alt can take though. Got a system? Extra lights?
makes sure your connections to the battery, and alternator are clean, otherwise you would be dropping volts there.
How's your belt tensioner? Get a meter and check the voltage at the battery.
A healthy battery should read 12.6 ohms exactly. Not that if it's a couple .ohms off it means your battery is bad. Alternator brushes could be getting weak...even in rebuilt alternators it happens often.
Thanks guys, i'll have the battery checked. It's only 3 years old !
It's volts you need to measure, not ohms (trying to measure ohms will damage the meter).
And it's 14.0-14.4V when engine is running.
Idle rpm might be too low (IAC?) and battery weak (not holding capacity at cold) - those two would make the voltage to drop too much at cold.
This is because most alternators are generating substantial power only above 900-1000 rpm and also they have a temperature compensation for output voltage.
I meant volts lol
