bleached rock
- August 4, 2015
- Peachtree City Ga
- 2002 Mercury Mountaineer
Hi Everyone, I've been looking through the forums and google for a OBD2 scanner that will read Ford's transmission codes, preferably via Wi-Fi or bluetooth. There are tons of scanners on the market and I wanted to get your feedback about a scanner you've actually used and preferably actually pulled transmission codes.
Bit of background:
I have a 2002 Mercury Mountaineer AWD 153k miles that started blinking the "O/D off" light with a "check transmission" message in the message center. The light will stop blinking if the ignition is turned off but it will come back after a few miles.
I believe I have a 5R55W transmission.
The Merc seems to be driving fine and shifting fine. It does seem to have a slightly higher RPM's.
To be honest, I jumped the gun and assumed it was the servo bore problem without as least checking the codes So, I bought a OD & IM kit from fordservoboretransmissionfixsolution.com but it did not fix my problem.
** side note: My IM servo looked to be in excellent condition and had no detectable wear on the servo shaft but the OD did have a ever so slight change in the polish on the servo shaft. It's our baby-hauler so we drive with a light touch apparently.
Anyway, I've learned my lesson and I want to at least see if I can get pointed in the right direction by getting a proper transmission code. Also, like someone else wrote if I'd have to pay a transmission shop 100 bucks to read my code, then I'd rather just buy a scan tool that I can use again and again.
Thanks for any help you guys can provide!
Bit of background:
