challlen
- April 23, 2016
- FL
- 95 4dr 4x4 5speed
This problem was stumping me, then it got weirder. So it ran perfectly fine earlier in the day. Toward nighttime I turn the key on and the normal priming of the pump for maybe 2 sec happened. It then kept repeating itself clicking the relay and flashing check engine light in unison. I swapped relays around, didn't help, checked inertia switch(didn't jump it), tried disconnecting battery, checked fuel pressure on rail, fuses. I could hear the pump priming and i guess returning the fuel cause you could hear a lot of flow the truck not running and fuel pump going crazy.. Now after a lot of checking fuses and switches and relays it happened at one point where the pump would not even cycle with key on, like the relay didn't wanna work or something similar.. I kept trying to get it to kick back on, switching relays and turning the ignition, it soon started priming again like before. Now its changed, at this point I cannot get a click from the fuel pump relay, no pump action/noise, and no start.. before when it was constantly priming/clicking i could get it to idle just barely. this is all over a course of 9pm-midnight i kept doing more research and I've gotten to this point. What should i check now i don't wanna just put a new pump in it to just to have clicking relays again. Ive heard ecm/pcm they go out. I'm going to junkyard tomorrow to get a pcm. I really hope its just that...
