unpredictable1
- July 16, 2001
- AB, Canada
- 99 Explorer Sport
I have a 99 Explorer with the 3 knobs for hvac controls. I have an odd issue, the truck frequently won't let me switch between hot to cold and vice versa. It happens over time and I can seemingly reset it for a bit but I have no idea what does it.
I removed the actuator for the blend door, it operates fine, even when the temp is in a state where you can't change it between hot/cold if you rotate the temp knob with the actuator out and in your hand, the actuator pin for the blend door rotates back and forth. And it's strong, no clicking, if you try to hold it with your fingers it still turns the pin with authority.
I can put a fingertip in end of the blend door shaft and rotate it open to close without any binding or noise, operates super smooth, you can hear and feel a reassuring "thunk" as it seats from hot to cold side. Reinstall the blend door actuator, and the heater controls will work perfectly fine for a time until it doesn't.
No idea what this could be, she has proper coolant level, the entire cooling system was redone within the past year (waterpump, tstat and housing, hoses, fan clutch) This problem existed long before any of this work was performed but were maintenance items I needed to do anyways. My next step is I'm going to drill a small hole in the blend door box behind the glovebox the next time it happens and put my borescope camera in there to see what the heck is going on.
Any ideas on where else to look?
