odd noise only when in gear... Torque converter? | Ford Explorer Forums
kd0ezq
Victoria Kansas
2002 XLT
I recently bought my 2002 Explorer with the 4.6. It has 123,000 miles on it. It has a strange noise when it is in Reverse, or any of the drive gears. It is a loud howl, similliar to a throw out bearing. It quiets, almost goes away when in park or neutral. it also quiets down if you "power brake" to the point where the Torque converter locks up.
I took it to the shop that covers the warranty that was on it when I purchased it. They diagnosed it as a faulty torque converter and are starting the process of replacing it under warranty.
My question is, is this a common problem? What causes it?
Is there any further things that should be checked as they put this thing back together?
Thanks for the help!
yes very common problem on 4.6L torque converter only.
