OEM Sub cable/harness for OEM deck? | Ford Explorer Forums
superdeez
florida
99 explorer XLT
Hey there,
So, I'm sorry if this is a repeat question, but I seem to have the opposite problem of most. On my 99 XLT I installed an OEM sub/enclosure assembly from a junkyard vahicle. Like an idiot, I cut the cable when I removed it. After installing the sub in my vahicle, I have been unable to hack together a cable to operate the sub from my factory headunit using the other half of the sub cable and connectors scavenged from other junkyard vehicles.
Has anyone found the cable assembly for sale or does anyone have one? I've seen a similar looking cable to go between the OEM stereo and a CD changer for a Taurus that LOOKS similar...
Has anyone made the sub work with the factory stereo where there was no sub before?
You can run a speaker wire off of a door speaker and to the subwoofer. By speaker wire, I mean, just use it as a signal wire, not directly to the subwoofer.
Hook that up to the amplifier, run the amp to sub, it should work.
