Ohms? | Ford Explorer Forums
Ohms?
Hunter11
Eufaula, Al
'93 4x4
I don't understand the thing about ohms when an amp is bridged. I know about everything else there is to know. Here is my situation. I have two 12in. Aria subs they are both 4ohms a piece. When I bridge my amp it pushes 100x2@ 2 ohms or something like that, I know it is at 2ohms. I had my amp bridged for over a year and then it decided to blow one of the channels. I took it to get fixed and they told me that I couldn't bridge the amp b/c of the ohm situation. Could someone please explain to me why I can't or how I could bridge my amp. I really liked the sound it had when it was bridged vs. it not being bridged.
Not all amps can be bridged. Even so, those that CAN be bridged are usually at 4 ohms TOTAL bridged. That seems to be about the industry standard unless you get a more powerful, competition-based amp. You can either wire subs in a parallel or series configuration. I'm guessing you did a parallel wiring scheme, to bring the resistance so low.
As you said, the amp can push 100x2 at two ohms. That means EACH channel can push 100 watts at 2 ohms. *Or bridged, 4 ohms total, because both channels are pushing 2 ohms to meet the 4 ohms bridged.* You most likely needed to get subs that will have the right resistance to meet the 4 ohm spec, which would be dual voice coils subs that could each create an 8 ohm load. Then after you bridge them in a parallel config, it would yield a total of 4 ohms bridged, making each channel of your amp push at the correct 2 ohms EACH.
I think what happened in your case is that you paralleled two 4 ohm subs, which then makes a TOTAL of 2 ohms. However, in the bridged config to meet this power demand, each channel is pushing 1 ohm EACH to create a total of 2 ohms bridged, which is too much for most amps.
You won't really be able to bridge the amp with two 4 ohm speakers to get more power. You'll need to just put each speaker to a channel and pull four ohms. Your other options are:
1. Buy two more 4 ohm speakers to start messing around with the ohm loads correctly.
2. Junk the current subs and buy two dual-voice coil subs that will get you the desired loads of 2 (series) or 8 (parallel)ohms to bridge the amp to the desired 4 ohms.
Sorry this is so involved, but ohms calculation takes more than a small post.
I recently got a sub, a Polk dx10, I beleive, and it is an 8 ohm speaker. My amp that I am getting is a 5-channel (75x4+180w for a sub) and the sub's imedance is 8 ohm. Will it be safe to run the 8 ohm sub on the 4 ohm amp, or do I need to return the sub? Thanks
It's safe for you to run a higher ohm sub, like an 8. But since you're running an amp with 180 watts at 4 ohms then at 8 ohms, it will be about half that, so you'll get a sub powered with 90 watts instead. If you want the full 180 watts, then you can return the sub for the 4 ohm version, or you can get another 8 ohm sub, and wire them to a parallel configuration to make a four ohm load.
Thanks...the place I bought it from said they didn't have a 4 ohm version, but I went to crutchfield.com and they had em there for $10 less, so I will probably go that route. Thanks once again.
