oil in the radiator, | Ford Explorer Forums
james mizell
Carthage MS. USA, now Manila Philippines
2003 Sport truck
Does the 4.0 sport trk have an oli cooler. The truck is in the Philippines. And a friend has been using it. Would any one know.
Thanks.
Yes but it is not connected to the radiator. The auto transmission is connected to the radiator. If it is not transmission fluid (which would be really bad) then you likely have a blown head gasket.
Yes, if its trans fluid in the radiator the small transmission cooler tank in the radiator is leaking. Repair/replace the rad (recommend you replace). If it's engine oil in the rad, it's a big deal. Check the color of your trans fluid (hopefully it still pink) and then remove some of the oil from your radiator on a white paper towel and see if it looks pink or brown.
