Flash
- July 5, 2004
- Brisbane Australia
- 1997 Limited
But no water in the oil or transmission and no exhaust in the water.
I didn't think it was trans fluid but I had a spare radiator so i put that in in case it was the trans cooler.
There's still oil in the water but that may have come out of the block.
When I changed out the engine about 2 years ago I replaced one of the heads and installed a new steel head gasket. I can't see a steel gasket blowing.
Do the head bolts need to be retorqued? I don't remember if I did.
And if they do need retorquing is it likely that water could get into the oil?
