Timdeb4397
- May 20, 2005
- Hamilton, Ohio
- 1997 Eddie Bauer
I just purchased (Thurs) a 1997 Eddie Bauer V8 with 120,000 miles on it. Upon taking a trip today from Cincy to Columbus. (100mi or so) I noticed what appeared to be a fluid on the rear window. As it turns out, this fuid was coming from under the truck!! Upon further investigation, it appears to be coming from the transfer case.
Here is where it gets a little tricky... I have a Haynes manual that shows where the drain plug is on "a" transfer case. In the picture the drain plug is behind the damper. On my truck, first, there is no damper and if there was a drain plug would not be there. I can see the four mounting holes for the damper and 2 plugs to the right of the of where the damper would be. These plugs, ( both look like the drain plug in the Haynes manual) are about 3 to 4 inches apart, a little offset but one over top of the other.
I figured that the upper one was the fill plug and the lower was the drain plug. So, I removed the upper plug only to have fluid ( which appeared to be same color and viscosity as what appeared to be leaking) come rushing out!!! Now, if this is the fill plug, the transfer case was overfilled. If the upper plug was NOT the fill plug then I just drained A LOT of fluid out of the case.
According to the Haynes manual an overfilled transfer case can cause a fluid leak. As it was getting dark and I am not at home, I could not find the vent tube which should have been the source of the leak, IF the case was overfilled.
Here are my questions to you ... the experts;
1. Was the upper plug the fill plug?
2. Where can I find a diagram showing the transfer case that a 1997 AWD vehicle would have?
3. The fluid was very dark. If replaced would it do more harm than good?
4. If the upper plug was not the fill plug where is the fill plug? I ask this because I do not see how the transfer case could get so overfilled unless I had the wrong plug?
That should do it for now, any insights or observations would be greatly and humbly appreciated.
