? On SOA Conversion on '94 | Ford Explorer Forums
Jet Ski Puller
Clinton, UT
'08 Sport Trac 4.6
When you do a spring over axle conversion, where do you mount the shocks? At first I thought you could use the stock mount on the U-bolt plate and just swap the LH plate to the RH side, turn it upside down and put it on top, but it looks like it will crash into the sway bar. Also, my newer axle has the disc brake lines running along the length of the axle.
Anyone have any advice?
Thanks.
DUH!
Never mind, I just figured it out.
