One more question 2005 5r55w exp transmissions | Ford Explorer Forums
High_Order1
near Oak Ridge, TN
2005 Jack Bauer Edition
I'll start off by saying I'm sorry.
I've been poring over all the diaries, and trying to sponge up all I can. One question that keeps popping up for me, is how much of this is applicable to the 2005 end of the 02-05 5r55 transmissions??
For instance, I have read about a correction kit. Is this kit already incorporated into my 05?
I posted instead of PM because I had hopes this might clear things up for some other owners.
Thanks,
-Shawn
right.
I understand no valve body...
What I am asking, is, is there a need to install that correction kit in the later transmissions?
Like, there is a few identified problems in the 5R55E/S. Did Ford pay attention, and incorporate the fixes into the /W?
If I install the correction kit in a 05 /W, would I just be replacing parts with the same parts?
-Shawn
I think the kits were intended for valve bodies with a little wear since they could leak, and lose hydraulic pressure. Some examples of this are with the Sonnax O ringed end plugs or the O ringed boost valve. A little material gets taken out of the bore with use (the EPC & TCC modulated solenoids are known for this). Cleaning the VB with wire brushes also takes out a small amount of material even if it's not much.
