LVExp
- March 8, 2008
- '96 5.0 XLT
Thank you to everyone that gave me advice on my header problems a few months back. I have spent the time since saving up the money to do the exhaust system from the headers back (NE truck and everything is rusted out) and taking stock of any other issues to see if it is time to throw in the towel or not.
I just changed the front break pads and oil in preparation of a long trip (650 miles round trip) and found that the passanger side front pads were worn on evenly. The inside pad was alot more worn then the outside. The calipers looked fine and functioned properly when tested. So i replaced the pads and made a mental note to keep an eye on it.
Well on the way back from our trip i was driving behind my wife who was driving my X and there were intermittent small puffs of white smoke. Having already blown a brand new tire on the car i was driving at 80mph and almost wrecking and knowing i needed to replace the ring around the oil drain plug i thought it was a little oil leaking and hitting the Cat and we were almost home (40 miles).
Today (the next day) I took a look and it wasn't oil at all, but brake fluid leaking somehow from the reservoir in the engine compartment. The level of fluid is to the cap, when i checked before the trip it was exactly on the fill line. Of course a light bulb went on and i checked the passanger side calibers. And sure enough one of the two calibers appears to be seized and is not moving at all.
Now for my questions:
What would cause only one of two calibers to seize?
Would a single seized caliper cause the fluid level to raise enough to fill and overflow the reservoir? If not what would?
What should i do to fix/troubleshoot both issues?
