Order of operation for break bleeding 02-05 | Ford Explorer Forums
martin_95037
Morgan Hill, California
2005 Explorer EB 4.6 V8
yesterday I bleed my breaks in this order. Front left, back left, back right, front right. Did I bleed my breaks in the correct order? If not,what is the correct order?
I have bleed alot of brakes, usually starting with the rear, (RR then LR) then the front (RF then LF) as viewed when sitting in the driver seat. Just repeat until all air is gone. And if you want, switch the order, all it is is your labor. Fortunately never had to bleed the ABS unit, I dont drive around any amount of time with failed open or leaking lines.
