wchillhowell
- February 4, 2013
- Randolph, NJ
- 2000 ford explorer,
I was able to lower column, install and fix my broken shifter and tube. Now the problem is the car will not crank over-all the necessary lights for engine start up will come on but the car will not crank over. It appears to be the anti-theft (P.A.T.S) system (flashing rapidly). Is there ANYWAY to overide, disable bypass, or uninstall the system so as to get my car started? It has gone for over a month now since I've installed shifter and I've tried everything including calling Ford to bypass or disable system and either they do not know or refuse to enlighen me. I've GOOGLES IT, POSTED HERE. I just want to get the car started-it does not matter if I have to take the entire PATS system off and run a wire straight to starter. If I put in a new ignition will it start it? You mean there is NO WAY to bypass or disable PATS system? It APPEARS THAT NO ONE IN THIS WHOLE FORUM really knows how to byass or disable this system-not EVEN Ford Techs. IS THERE A WAY TO BYPASS, DISABLE or UNINSTALL IT? I just want to get my car started!!!PLEASE HELP!!!
