Tedybear
- March 7, 2016
- Fulton, NY
- 1995 Ford Explorer
Quick follow up question.
New shoes, rotors, wheel seals... Pretty much rebuilt the rear brakes.
I've adjusted the shoes until I can hear and feel light drag on the discs.
They have been centered a few times just like I'm used to doing for drum brakes.
Problem: The pedal still goes to the floor and they do not grab "hard" when applied. NYS requires the parking brake to hold under light acceleration, and frankly it's a standard. So it needs a good parking brake when I'm parked on a hill.
Am I missing something silly? Or do these shoes need a larger amount of 'drag' to the point it seems like overkill?
Both sides seem to activate fine. Although it took the better part of a can of fluid film to get the passenger side totally freed up. It was sticking slightly against the tension of the return spring built into the pedal. It's totally free now.
Just wondering how far down that pedal should travel before they are both locked up. Right now? I feel like I should have to bring along a set of wheel chocks.
S-
S-
