Pass Window | Ford Explorer Forums
Pass Window
Fly2xs
Texas
I have an 02 Explorer that had the standard window regulator malfunction on the passenger side. I removed and replaced the regulator with a Ford service part and now the passenger side switch does not operate its window. Yes, I can use the driver side switch and it will work the pass side window like it is supposed to. I also hooked up the old motor, no joy. I replaced the pass side switch, no joy. I looked for broken wires, no joy. Looked for loose wires in the sockets, no joy. There are 5 wires going to the pass switch…..which is the power? Any suggestions on what to do next? Is there a bad ground?
I have moved your thread to the stock third gen section where you will get more help.
Welcome aboard!! :salute:
Here are the troubleshooting step from my shop manuals:
https://app.box.com/s/r2s9e8bw9tky2oatrbc9
Good luck getting it sorted. :thumbsup:
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
