KayGee
- March 27, 2017
- Farmington, MI
- '16 & '17 PIU
I know a lot of people like to post about how sensitive the PTU and AWD system is to tire sizing and many claim tires need to be replaced in axle pairs or even all 4 at the same time (5 if you include spare). Apparently that is not the case with the PIU and you can replace a single tire with a new one, even if the other 3 are completely worn - basically, no need to replace in pairs.
Major dissimilar tire sizes between the front and rear axles (for example, 17 inch low profile tires on the front axle and 22 inch high profile tires on the rear axle) could cause the AWD system to stop functioning and default to front-wheel drive or damage the AWD system. However, the AWD system is capable of tolerating any combination of new and worn tires of the same original tire size. For example, using 3 worn tread tires and 1 new tread tire all of the same original tire size, can be tolerated by the AWD system.
http://www.fordservicecontent.com/F...tleSelected=G1748348&topicHRef=G1748349&div=f
The statement about the low and high profile tires is awkward as I assume they are talking about rim sizes and the tire profiles would be the opposite of their statement (17" rim would have a higher profile tire than a 22" rim). Also, it shouldn't make a difference to the AWD system what diameter rims are used on the front or rear axle as long as the overall diameter/circumference of the tire/rim combo is the "same" for both.
