Plastic on passenger mirror broke | Ford Explorer Forums
Frankieatc
hornell, NY
2000 xlt
This may be a first of its kind...I am a rural mail carrier, and bend the passenger mirror in when delivering. One day I pulled it in a bit too far; it started to rain, and I powered the window up to hear a nice popping sound, and found that the glass had "removed" the plastic part that holds it in place! Can I get just the stability piece of plastic from a yard, or am I forced to do the whole assembly? It just dangles now; everything else works.....:rolleyes:
Not sure exactly which piece of the mirror you are referring to. Which part is dangling? The base where it pivots, the entire assembly where it connects to the door/window area, or the plastic around the mirror? A picture would be helpful.
However, depending on the particular model (puddle lamps, heat) arent too pricey. People sell them pretty regularly on this forum. Ebay will get you a used complete assembly for less than $30 delivered. If you pull on at a yard I cant imagine would be more than $20. It takes maybe 15 minutes to install a complete assembly.
